Make Audio Convesion Engine read subfolders
  • orangehenry
    • Jun 2011
    i'm new to the forum and dbpoweramp - I'd really appreciate some help.
    I'm trying to setup a way to automatically convert flac to alac. What I need is a watched folder so that new flac albums will be recognised and converted.
    I've installed Audio Conversion Engine and this almost works. It will see flac files, convert them and move them to a new folder without any intervention on my behalf. However, I can't make Audio Conversion Engine recognise files that are in a sub-folder.
    Does anyone know a solution to this?
    Thanks!
  • daren
    • 153
    Re: Make Audio Convesion Engine read subfolders
    The only way of doing this currently would be to create new profiles for each sub-folder, but this probably won't work for you if you want to drop whole folders into the watch folder.
    What we can do is add sub-folder functionality to the next version.
    Best regards,
    Daren.
    • orangehenry
      • Jun 2011
      Unfortunately I don't think that will work as the each sub-folder will have an automatically generated and unique name.
      Have you heard of any other way of doing what im talking about?
      Cheers
      • daren
        • 153
        ACE Lite version 4.10 can handle sub-directories. The new version is currently in beta and can be downloaded using the following link: http://www.trinitysoftware.nl/progs/...p?id=959029582
        An extra checkbox has been added to the profile settings. This must be checked to enable the use of sub-directories (default is off).
        One thing to watch out for: Make sure that your watch folder, processed folder and error folder don't have sub-directories (other than the ones you want processed). As with any beta, backup your data before you begin.
        Please let me know how you get on with this version.
        Best regards,
        Daren.
