Add Disc and Track to Title
  • m78
    • May 2011
    I have a question which I hope is easy to answer but I have not figured it out from the help or these forums yet.
    I have used Batch Convert sucessfully to convert my library to FLAC files with appropriate Directory and File names but I now need to alter the Titles to include the Disk and Track numbers.
    This so that my Marantz AV7005 will play tracks in the proper order from the built in UPnP server on my Linksys e4200 router. The tracks play fine from a USB drive connected directly to the AV7005 but the same drive on the server results in the tracks in Alphabetical order.
    Is there a way to use the Tag from Filename to just change the Title to be the filename?
  • dbfan
    • Jan 2011
    • 937
    Re: Add Disc and Track to Title
    Tag from filename can set just title to the filename.
    • m78
      • May 2011
      Thanks. I was stumped as to what to put in but just [Title] front to back seems to work on the files I have tested so far.
      Was too simple for me at first!
      Thanks again.
