normalisation
  • radium98
    • Jul 2008
    • 30
    normalisation
    hey all
    SPOON can u help me i was using for several time mp3gain to normalise my mp3 the normalisation is set to 98% ,what i have to do in dbpoweramp r14 trial to make the same option in normalisation as mp3gain to obtain same result and i will make a compare after
  • dbfan
    • Jan 2011
    • 937
    Re: normalisation
    Volume normalise Dsp set to the 98%
    • radium98
      • Jul 2008
      • 30
      Re: normalisation
      ********* thanks for ure quick reply but i cant see can u tell me were please.i have attached a print screen.
      please help me .tell me where
      thanks
        • 44044
        Re: normalisation
        That 98% is 98db target volume which is the default for replaygain, so nothing to change on the volume scale, just activate Replaygain
        • garyd9
          • Jan 2011
          • 39
          Re: normalisation
          98db or 89db?
            • 44044
            Re: normalisation
            Yes you are right it is 89db...
            • radium98
              • Jul 2008
              • 30
              Re: normalisation
              i have actinated reply gain in volume normaliser dsp and i saw the volume for all sound looks gd as 89 in mp3gaIN AFTER USING THE DBPOWERAMP ,but i need to maxi,ize it to 98% and not 89 can u help me more .
              thanks.:blush:
              • garyd9
                • Jan 2011
                • 39
                Re: normalisation
                thanks.:blush:
                While I don't know the answer to your question, I'd suggest NOT maximizing RG to 98dB. The reason is that RG doesn't work on actual peaks, but on percieved peaks - which might have actual peaks at 99% even using the default of 89.
                If you were to RG with percieved peaks at 98dB, you would likely end up with tracks that are clipping...
                • radium98
                  • Jul 2008
                  • 30
                  Re: normalisation
                  garyd9 thank u for reply and help i know that 98% will clip but 89% is to low so i try normalsing with soxx fxxxe and mp3gain work good ,but i dont like to uise them i prefer using dbpoweramp so why i asked ,if i cant do it with rg can i do it with volume normalise how these settings .
                    • 44044
                    Re: normalisation
                    Volume Normalize, replaygain selected and the 'Desired' section set to -0.2 dB will be 98%
                    • radium98
                      • Jul 2008
                      • 30
                      Re: normalisation
                      sorry for disturbance ,SPOON i tried as u said :volume normalize >>adaptive >>desired volume i put it also to 0 db ,than after conversation i analys the track with mp3gain seems to be 96% ,i assume that with reply gain only it work to 89% i also analys the track with mp3gain to compare ,finally it doesnt work any other idea.
                        • 44044
                        Re: normalisation
                        You would not want to increase the default level as you would get clipping (replaygain does not only decrease volume, for some tracks it increases it).
                        • radium98
                          • Jul 2008
                          • 30
                          Re: normalisation
                          yes SPOON in fact i want to increase the volume to 98% never mind if it clips i use final hardware limiter ,so what do i have to do to get 98% normalize for all tracks ,which dsp and settings ,please.
                          thanks.
                            • 44044
                            Re: normalisation
                            Try 0.2 dB (you can type positive values).
                            • radium98
                              • Jul 2008
                              • 30
                              Re: normalisation
                              :blush: not working i still get under the limit .the only one that work is rg but the level is 89 .and i need 98
                              thanks
