Why audio Conversion Engine wont recurse subfolders?
  • abelardopisani
    • Dec 2010
    Im trying to convert a directory tree with wma files into MP3.
    Instead of using forfiles and write a batch I found ACE, wich I liked. Im a user of db so I think it is fine to try it.
    The problem is that I cant get it to recurse folders, and on top of that if I create one profile for each folder, it will run only the first one I created.
    Any help?
    Thanks a lot
    Antonio
    Re: Why audio Conversion Engine wont recurse subfolders?
    Use 'Batch Converter' it is installed by default with dBpoweramp Music Converter.
