Mirroring original folder structure for batch conversions?
  • johnk
    • Sep 2009
    • 21
    I'm probably missing something very simple here, but I'll ask the question...
    I have my original files in: C:\Music\FLAC
    I create: C:\Music\OGG
    I want to use the Batch Converter to mirror the FLAC collection in the OGG folder, using the same folder structure. But if I set up the batch converter as follows:
    Folder: C:\Music\OGG
    Dynamic: [origpath]\[origfilename]
    I get, predicatably: C:\Music\OGG\Music\FLAC\......etc.
    Whereas I want to simply mirror the structure from the FLAC folder in the OGG folder. Does that make sense?
    • 44008
    Re: Mirroring original folder structure for batch conversions?
    Are there any further folders in the FLAC folder?
    • johnk
      • Sep 2009
      • 21
      Yes, plenty! The first level is FLAC\Pop and FLAC\Classical and then numerous sublevels, so an extreme example would be:
      G:\Music\FLAC\Classical\Mozart\Orchestral\Piano concertos\Piano concertos - Bilson\Piano Concerto No. 14 - Bilson\1 - Allegro vivace.flac
        • 5754
        try this (or something similar). This would create the same directory structure but leave off the first two folders (in your case MUSIC/FLAC)
        [TRIMFIRSTFOLDER][TRIMFIRSTFOLDER][origpath]\[origfilename][][]
        • johnk
          • Sep 2009
          • 21
          garym -- thank you for setting me on the right path. I had played around with [TRIMFIRSTFOLDER], but hadn't really understood it properly. Your help made me play around some more.
          All that was missing from your effort was another set of brackets -- you need to nest the first [TRIMFIRSTFOLDER] inside the second. So the correct path is:
          Thanks again.
