Audio Info does not show ID Tags
  • OldCoder
    • Sep 2003
    • 90
    Spoon,
    I looked for ID Tag fields (Artist, Album, Title) in the Audio Info output, but it does not show. Am I missing a configuration item somewhere?
    I tried checking "extensive" and unchecking it, neither show these fields.
    Meanwhile my Squeezebox keeps throwing files into "No Artist" and "No Album".
    Being able to see these fields in a spreadsheet would help me a lot.
    Thanks!
    Re: Audio Info does not show ID Tags
    Try on a file you know has tags, such as one recently ripped.
    • OldCoder
      • Sep 2003
      • 90
      I used one that shows everything when viewed by "Edit ID Tag" on the Win 7 context menu.
      File Name Length Channels Sample Rate (Hz) Sample Size Bit Rate (kbps) Size (Bytes) Uncompressed Size (Bytes) Compression (% of Original) Type Path
      A Felicidade (Adieu Tristesse) 00:02:47 2 44100 16 1411 17,451,512 29,494,080 59.2 ape File [.ape] E:\DMH Music\New\Antonio Carlos Jobim\The Antonio Carlos Jobim Songbook\
      Agua de Beber 00:02:19 2 44100 16 1411 13,582,299 24,691,237 55 ape File [.ape] E:\DMH Music\New\Antonio Carlos Jobim\The Antonio Carlos Jobim Songbook\
        Normally the extensive option lists all tag values contained within, example:
        Audio Details for: C:\Dido - Here With Me.ape
        Length: 4 minutes 15 seconds
        Channels: 2 (stereo)
        Sample Rate: 44.1 KHz
        Sample Size: 16 bit
        Bit Rate: 1,411 kbps (CD)
        Audio Properties:
        Audio Quality: Perfect (Lossless)
        Encoder: Monkey's Audio v3.97
        Encoder Settings: Normal Compression
        Sample Count: 11,247,852
        ID Tag: APEv2
        Contains: ID Tag [APEv2]
        Gapless: Yes
        ID Tags:
        Artist: Dido 1รบ2
        Track: 6
        Year: 1995
        Genre: soundtrack
        Title: Here With Me
        Album: Brit Awards 2001 (Disc 1)
        The field names of yours do not match mine, make sure you have R13 and the latest audio info utility codec.
        • OldCoder
          • Sep 2003
          • 90
          Spoon,
          My apologies....
          I ran again with EXTENSIVE, and they showed up, toward the right side in EXCEL.
          When running without extensive, they were omitted.
