Using DSP effects
  • Dakeryas
    • Feb 2010
    Using DSP effects
    Hello,
    I wondered if it was possible to use DSP effects to make the encoder fill in the Album Artist tag with the already present Artist tag?
    I know how to delete tags, but if I want to add the Album Artist automatically, I can't simply say "add AC/DC in the Album Artist" since I don't only encode AC/DC albums for instance :smile2:!
    In a nutshell I would like to know if dBpoweramp can copy the Artist tag into the Album Artist tag.
    Many thanks,
    Dakeryas.
    • 46164
    Re: Using DSP effects
    In the beta section of this forum is are new DSP effects, in the ID Tag Processing you can set rules such as
    IF [album artist] = ""
    SET [album artist] = [artist]
    (you would have to check the syntax of the above with the help file, as it is from memory)
    • Dakeryas
      • Feb 2010
      I have tried both:
      IF Album Artist=[anyvalue]
      SET Album Artist=[artist]
      and:
      IF Album Artist=
      according to the help, but none seems to work. What's strange enough is that there are no boxes to tick in the manipulation section for "Ruled Based manipulations", only a "set box" to write the rules.
      Any ideas?
      EDIT: While it doesn't work with "Manipulations" it does work with "Map", so in some way I've solved the problem.
