How do I override dbpa's Naming error about every track having the same filename.
  • bigbill
    • Mar 2009
    • 11
    I primarly use dbpa cd ripper to rip my audiobook to a single file per cd (rip as one). If the CD Meta data program is working correctly it will often have the correct info including the disc number in the "Album" tag. So the littoral "BookName"[album] in the Naming Tag field would work for me. But I get the error "Naming has to be formed using dynamic items (such as [title] or [track]) otherwise every track will have the same filename" Of course [track] is always = 1, which is useless. [title] is always = Rip as One, very useless again.
    So that makes autonaming a real problem.
    Anyone found a way around that?
    • 46224
    Re: How do I override dbpa's Naming error about every track having the same filename.
    Can you not use [title] - [album]?
