Rip error on first track
  • ajitga
    • Oct 2009
    Every time I rip a CD, the first track show an error, while all the other tracks are accurate or generally fine. I then have to redo the first track and it will rip fine the second time.
    Am I missing something with my set up and how can I fix this?
    • 46164
    Re: Rip error on first track
    What is the exact error shown?
    • brian2090
      • Oct 2009
      Perhaps spinning up the drive first could solve the problem... there is a setting for this, of course, so I'd give it a try.
      FYI, I found that over-reading the lead-out sectors can cause the final track to fail AccurateRip, so I had to disable that function for the bulk of my CDs.
      • ajitga
        • Oct 2009
        The first track starts to rip and stops at around 15%, starts to encode and finally there will be a red cross and the word error under Rip Status column. All the remaining tracks will rip accurately. I have a second drive on my PC and the results are identical. Since I do not know how to solve this, I will rerip inaccurate and insecure tracks and this will then rip the first track.
        • matze2303
          • Dec 2009
          Hello, was there a solution provided? I have exactly the same error message. It asks something about "disk full?" which is definitely not the case. It is, by the way, a network path to my NAS.
          Regards
          Matthias
            • 46164
            If there is an error on the first file, something is stopping the file from writing on the NAS.
            • paa-sme
              • Feb 2010
              Was there a sollution on this? Got the same problem. Uses NAS.
              • kaptkroll
                • Mar 2010
                I don't get a rip error on the first track but other tracks on the CD. I've had this happen on new CD's where I know there is not a scratched CD. The program will automatically re rip different sectors but this takes 40 minutes for one track. What can I do to avoid this?
                  • 46164
                  Answered on your other thread.
                  • paa-sme
                    • Feb 2010
                    Was there a sollution on this? Have the same problem. Ripping to NAS. Flac. Nothing to do with spin up time. The problem is gone with saving on local drive.
                      • 46164
                      It means your windows pc does not have access rights to write to the nas.
                      • paa-sme
                        • Feb 2010
                        OK, thanks Spoon, but what can be problem? It is only on the first track. It has worked just fine before. It is a warning about a problem with the sertificate when I`m accsessing the NAS. It says that the sertificate is for another WEB area. Can this be the problem? What can I do for fixing this? Thank`s a lot!
                          • 46164
                          You would have to ask on the support site for your NAS manufacturer.
