no gap between mp3 track rips with dbpoweramp
  • bastet
    • Sep 2009
    • 9
    :(How do I eliminate the annoying gap that sometimes occurs when one rips music from cd's that have no distinct track seperation (like on the Beatles Abbey Road For instance). I sometimes get an artifical gap between the tracks on playback from ripped files before the next track starts.
    How can I eliminate or even shorten the time gap so that the rip plays seamless exactly like on the cd?
    • 6188
    Re: no gap between mp3 track rips with dbpoweramp
    LAME rips are gapless. You don't need to do anything special. Abbey Road plays as intended. Of course all this assumes your PLAYER deals with gapless ok.
    • bastet
      • Sep 2009
      • 9
      ah so! thanks GARYM :smile2:. So it's the PC player that I am ripping with ( a Pioneer DVD RW DVR 108) , can I alter the settings or what to prevent the gaps?
        • 46184
        It is not the DVD drive, it is not the ripping software (every CD Ripper will rip gapless if the album is gapless). Mp3 does have gaps, which certain audio players can remove if they can identify the audio encoder (such as lame).
        • Teknojnky
          • Dec 2006
          • 323
          what player are you using?
          what lame settings are you using?
          Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
          Want a random mode based on track and artist relationships?
          [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
          [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
          • bastet
            • Sep 2009
            • 9
            Thank you for your support :smile2:
            I rip with dbpoweramp Bitrate (CBR) with 320kbps
            my mp3 player is a Creative MuVo v 100
            maybe I am not using the right settings with dbpoweramp.
            It does not happen automatically.
            I just can't figure it out
              • 6188
              No, it is not the PC player, it is the MP3 player that must play gapless. Even though your LAME files are capable of gapless, the MP3 Player itself must also use this information. There are some players that do and some that don't. I don't know about your player in particular. So it is NOT dbpoweramp settings ,etc. You should try to do some searching to see if anyone can confirm that your player does or does not deal with gapless.
              • bastet
                • Sep 2009
                • 9
                Can I fill in a zero second command between tracks with Lame when ripping ? :headbang:
                With the effect that two or more tracks blend in together seamlessly?
                  • 6188
                  I'm afraid you are attacking the problem from the wrong side. I'm convinced that your problem has NOTHING to do with ripping or converting or LAME settings. If your MP3 PLAYER won't recognize the gapless info that is AUTOMATICALLY in your LAME encoded mp3 files, you will NOT get gapless. Again, are you sure that your player will deal with gapless correctly?
                  • bastet
                    • Sep 2009
                    • 9
                    I'm afraid you are attacking the problem from the wrong side. ...... Again, are you sure that your player will deal with gapless correctly?
                    First of all thank you garym for your patience. As you have noticed I am a novice to this subject.
                    No garym I am not sure about the Creative player. And I really failed to think that it could be the problem.
                    I will now see if I can get assistance; ....hmmmm...however now with your information, and as I have just last week bought a iRiver E100 ( I have not had the time to unpack it) , maybe just maybe it will not manifest itself with it.
                    • drjenkins
                      • Feb 2006
                      • 42
                      Here is just one of several reviews of the Creative Muvo which state it does not support gapless play:
                      The cons:
                      * Doesn’t support gapless play
                      -drjenkins
                      • bastet
                        • Sep 2009
                        • 9
                        -drjenkins
                        It is evidently the source of my problem
                        thank you drjenkins. I have learnt a lot from you people here, and thank you all.
                        • bastet
                          • Sep 2009
                          • 9
                          So does the iRiver E-100 support gapless ? :thumbdown
                          Nope!, I have been checking out and it does not!:thumbdown
                          So I bought the wrong player :vmad:
                          But I wanted a player with flac capability
                          After surfing the matter and delving into the tech specs,reading reviews etc.
                          I note that as far as I can tell, that the Trekstor Vibez is maybe the only player available that supports flac and that has gapless
                          What do you people say? Any views or advice on other players?
                          I think I will return the iRiver E100 and get the Trekstor Vibez instead :smile2:
