how do I fix the audio that was killed by dbpoweramp ?
  • thelittleone
    • Mar 2009
    Hello,
    I installed the dbpoweramp music converter r12.3 with a lot of plug ins- not all of them. I converted some files (flac to wma and flac to lossless). I finished the conversion, then the syncing to ipod. I had to restart my computer.
    After rebooting:
    I DO NOT HAVE ANY MORE SOUND / AUDIO from any player. The only sounds that I can hear are the sounds of Windows (from start-up or shut down).
    VLC, WINDOWS MEDIA PLAYER, YOUTUBE, ITUNES - NONE OF THEM CAN PLAY THE AUDIO. ALL OF THEM CAN PLAY THE VIDEO BUT EVERYTHING IS LIKE ON MUTE.
    I still get the audio errors from windows when something pops up.
    Itunes shows this error:" iTunes had detected a problem with your audio configuration. Audio/video playback may not operate properly " !!!!!!!!!!!!!!!
    there is not even one player (out of maybe 6) in my computer that can play the audio.
    I reinstalled the audio/video drivers from the motherboard. Nothing changed.
    What should I do?
    Re: how do I fix the audio that was killed by dbpoweramp ?
    Nothing to do with dBpoweramp Music Converter as it does not touch the sound card...
    • thelittleone
      • Mar 2009
      thanks spoon,
      But I did not do absolutely nothing else. I had to restart because usually I can't see my esata hdd without restarting.
      I do not know where to start !? :o:(:cry:
      thanks.
      • Teknojnky
        • Dec 2006
        • 323
        esata should normally be hot pluggable/unpluggable.
        maybe your having hardware issues (motherboard)?
        Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
        Want a random mode based on track and artist relationships?
        [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
        [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
