how to make ripper get and output right track names
  • eramos581
    • Nov 2008
    Just before I rip an MP3 file from my CD the application is supposed to go to CD database and get the right track title and artist names.
    Depending on the CD, it is getting this data reversed inserting the artist name under the track title field and inserting track title under the artist field thus after your rips your output MP3 tagged data are messed up (track title and artist names are reversed in the output tagged data). How do I get the application to not mess up like this?
  • Wayne
    • Aug 2002
    • 1254
    Re: how to make ripper get and output right track names
    The CD ripper should tell you where it obtained the track/artist information from. Where does it say it is it getting the information from?
    The problem is most likely with the meta data at source rather than the CD Ripper.
    • eramos581
      • Nov 2008
      It is getting the data from the freeb.org database. Other ripper applications I use with the SAME CD do not retrieve the title and artist data in reverse order.
      • Wayne
        • Aug 2002
        • 1254
        Which album is it? What are the other ripper applications?
        • bhoar
          • Sep 2006
          • 1173
          Can you post the log output so we can see an example of what is going on?
          -brendan
