delete naming conventions
  • Chip
    • Aug 2008
    • 102
    How do I delete a Naming Convention that I no longer want to use?
    I have tried to select the naming convention and then right click and click Delete but the naming convention seems to stay in the list.
    What do I need to do to finally delete old unused naming conventions?
    Chip
    • 45569
    Re: delete naming conventions
    They will be stored in the registry HKCU\Software\Illustrate
      More Precisely:
      HKCU\Software\Illustrate\dBpoweramp in a key named "CDRipper_Namings".
      • Chip
        • Aug 2008
        • 102
        I do not have the Key that you mention in your reply.
        When I look in the registry using REGEDIT I can see the following keys:
        HKEY_CURRENT_USER\Software\Illustrate\dBpowewramp
        \CDRipper\
        CDRipper\_DriveSettings
        CDRipper\Profiles\(default)
        CDRipper\Profiles\Compilation
        CDRipper\Profiles\Soundtrack
        \CodecOptions
        \dAP-KeyControl
        \DecoderCache
        \Ref
        \Skin
        Tagging
        I do not see a key called "CDRipper_Namings" in the registry.
        Can you give me an idea of what I may be doing wrong?
        I am using dBpoweramp r13 reference registered version.
        Of course just after posting this reply I found the key value you mentioned in your reply. I was only looking at the folders and did not look carefully enough into the folders to find the key.
        Thanks for your help.
        Last edited by Chip; September 20, 2008, 07:37 AM. Reason: Call of the search, found the key
        • neilthecellist
          • Dec 2004
          • 1288
          For future reference, you can just type it in a search window within REGEDIT by pressing CTRL and F . It's saved me a ton of time from having to search up exact keys manually.
          Last edited by neilthecellist; September 21, 2008, 02:37 PM. Reason: bad semantics = fixed :)
          • DrForce
            • Jan 2017
            • 13
            This is an old thread I found via search.
            How do I delete the naming strings in the Mac version of dbpoweramp? I have several old strings that I no longer need. I don't see an option to do it in the application itself. Thanks.
              • 45569
              I do not think you can selectively.
              • DrForce
                • Jan 2017
                • 13
                Found it on mac.
                Quit dbpoweramp and open the following file in a text editor and scroll to the bottom. You'll find the listings there:
                Code:
                ~/Library/dBpoweramp/XRegistry
                Each folder path and naming convention is listed under the following names:
                Code:
                "dMCLastFolder-0"
                "dMCLastFolder-1"
                &*8230; and so forth
                Delete the ones you don't want.
