Ripping Audio Cd's to BWF incl. Metadata
  • toneheads
    • Aug 2008
    Hi there
    i downloaded the latest version to figure out how i manage to rip cd's into Broadcastwave Files. Uncompressed for e.x. in 48 Khz 24 bit.
    I need in the bext field description for ex. Artist + Title + album,
    How do i manage this. the manual isn't up to date because the pictures are different and the menues also.
    regards Frank
    Re: Ripping Audio Cd's to BWF incl. Metadata
    Reading / Writing (reference only) of wave BEXT ID Tags, bext tags are: Description, Originator, OrigReference, OrigDate, OrigTime, TimeReference, CodingHistory
    • toneheads
      • Aug 2008
      ok
      i downloaded the demo the powerpack etc. but wasn't able to get bwf files out of the cd-ripper programm. where is my mistake ?
      frank
        Check in dBpoweramp Configuration you have a reference trial, also on Music Converter tab make sure 'Professional frequency conversion' is switched on.
        Run the CD Ripper >> select Wave codec - change to 48KHz and 24bit, insert a CD and add a custom ID tag for one of the tracks 'Description', rip the track and a bwf bext tag is written.
        • toneheads
          • Aug 2008
          Hi Spoon
          thanx for your fast response. I figured it out.
          But now the second problem:
          i like to have a combination of Tags in the bext description field.
          for e.x
          Artist + title + Album
          I didn't find a solution to do this
          when i made 3 entries in the mapping window like this one
          Artist description
          Title description
          Album description
          only album is written. is there a trick to get all entries into the description field?
          frank
            Only by manually doing it for each disc (copy to artist and keep the artist mapping).
            • toneheads
              • Aug 2008
              any chance to get this ?
              in a prossional manner.
              i also need a function to get a custom tag into the bext description field.
              frank
