How do I(!) solve this tag problem with a portable player?
  • matt_t
    • Feb 2008
    • 80
    I ripped my CDs to MP3 using CD ripper, all tagged with ID3v2.3.
    I have a portable player (it's a UK store's own brand, so not much point giving make/model since no-one will have heard of it) which displays track info like this, with Album and Genre reversed:
    Title: Suzanne
    Artist: Leonard Cohen
    Album: Folk
    File[??!]: Songs of Leonard Cohen
    Experiment showed it displays WMA tags like this as well.
    The easiest workaround (I have contacted the manufacturers, but I'm not holding my breath!!) would seem to be to use ID Tag Update to reverse the Album and Genre fields. BUT - how does one do this? If you map A - B you can't also do B - A because B is now A, so the two end up the same! Hope you follow that.... :teufel8:
  • matt_t
    • Feb 2008
    • 80
    Re: How do I(!) solve this tag problem with a portable player?
    OK, I have answered my own question, although maybe there's a simpler way. Spoon??
    Map
    1. Genre -> Style
    2. Album -> Genre
    3. Style -> Album
    Delete
    1. Style
    This is a bit like the farmer trying to take a wolf, a sheep and a cabbage across a river, isn't it? I never was any good at maths.........
      • 46198
      I think you can map a to b and b to a as it remembers the start values, did you try it?
      • matt_t
        • Feb 2008
        • 80
        Tried it, and both end up the same rather than reversed.
