How Do I do a DSP only conversion?
  • xerophyte
    • May 2008
    • 64
    How do I do a DSP only conversion? Specifically select all tracks of an album and use DSP to add album art. I inadvertently did this to a 192kbps mp3 and ended up with a (nominally) 320kbps mp3 so the damage is not terminal but I don't want to repeat the mistake.
    Re: How Do I do a DSP only conversion?
    Codec Central >> Utitility codecs (at bottom) and install [ID Tag Update]
    • xerophyte
      • May 2008
      • 64
      Hi Spoon,
      That was fast!
      I don't think I framed my question very well.
      I have DSP installed and I know how to access one or a number when doing a conversion. Where I goofed was trying to simply add album art to all tracks of an album. The tracks were 192kbps mp3, and the converter was set to 320kbps mp3 from the last conversion I had done. So when I ran the conversion with the sole aim of adding album art to all tracks I also converted them to 320kbps mp3. In order not to repeat this mistake I need to know how to set up the converter to just do the album art, or possibly some other DSP in the future.
      I hope that is clearer than my last post.:blush:
        You can't do a DSP-only conversion. The closest thing is two of the DSP effects, ID Tag Update and ReplayGain, have been made into "utility codecs" that can be run by themselves.
        • xerophyte
          • May 2008
          • 64
          Hi LtData,
          Thanks for clarifying that for me.
          I appreciate your help, and the forum!:smile2:
