I have a large music library with which I am trying to reorganize the entire file/folder structure based on tag info. The "Batch Converter" tool can do this but it looks as though there is no way to avoid applying some sort of conversion as well. I have no need to convert the files to another format, and it seems like a waist of time to have the enire library encoded to it's original format. Is there any way to use the Batch converter without actually doing a file conversion? This would be usefull for applying the "ID Tag Processing" action to an entire library as well.
Neil
Neil
