Help to upgrade from R10.1 to 11.5
  • nydana8
    • Jan 2008
    - Hi,
    I have 10.1 and need to upgrade to 11.5 which has the IEEE Float functionality. I got my dbpower via my Radio software. FYI: I am also using it to convert Classical Music and jazz.
    My questios are:
    1) Are there any major changes between the 2 releases that I need to be know about?
    2) Do I need to unistall and reinstall or the software can just update the existent files?
    Thanks a lot!
    Dana
    Re: Help to upgrade from R10.1 to 11.5
    To upgrade from r10.1 to r11.5, just install r11.5 over top of dMC r10.1. Also, you probably need to update your codecs. You need to get your codecs from Legacy Codec Central, NOT the main Codec Central. A link to the Legacy is in the main Codec Central.
      • 46130
      You are proabbly better on R12.
