I uninstalled dbpoweramp. How do I remove it from right click Start menu?
  • janbrown56
    • Jan 2008
    I have uninstalled dBpoweramp through the Add/Remove programs. When I right click Start, dBpoweramp Batch Convert is displayed along with Open, Explore, etc.
    How can I remove that? i am assuming that it is somewhere in the registry but I have been unable to find it.
    Thanks for your help!!
    Re: I uninstalled dbpoweramp. How do I remove it from right click Start menu?
    Which version did you have?
    • janbrown56
      • Jan 2008
      I honestly do not remember what version. Since it's been uninstalled, I cannot check.
        Try the removal tool here: http://forum.dbpoweramp.com/showthread.php?t=13285
          It will not help (link above).
          There was an issue with an eary R12 release, it was fixed in R12.1, R12.2, etc (we are R12.4 now), so install R12.4, then uninstall and it will remove that item.
