MPEG4 Right Click
  • sethm
    • Feb 2007
    • 23
    MPEG4 Right Click
    I can rt click on an MP3 or WAV file for converting, but not on a MPEG4 file (to convert to an MP3). I have the MPEG4 codec.
    Is there a work around?
    I am still using version 11.5 converter.
    Re: MPEG4 Right Click
    What is the extension of that file, m4a or mp4 or something else? Did you install the Legacy mp4 codec from Legacy Codec central?
    • sethm
      • Feb 2007
      • 23
      I have a MP4 codec, not sure if its a legacy.
      Are you refering to the encode & decode under section mp4 / mp3 / mp2 Specific- found on
      http://www.dbpoweramp.com/legacy/cod...ral-legacy.htm ?
        Check dMC Configuration (See "Need to find your version number?" below to see if dMC sees the codec. If it does see it, you are using hte legacy codec. If it does not, you need to install the legacy codec. And yes, that link you provided is the correct link for you to get your codecs.
