FLAC codec problem
  • budster
    • Nov 2006
    FLAC codec problem
    When I click on "convert to" I continue to get the pop up instructing me to install the FLAC codec which I have done multiple times, but the program does not appear to regognize this and will not allow me to proceed beyond this step
    Re: FLAC codec problem
    Did you install the codec to the same location as dMC is installed to? Did you install the codec and dMC as an administrator.
    • Dryden
      • Jan 2005
      • 30
      I just recently started getting the same problem since I started using the new Foobar release to create FLAC files. Db can recognize older FLAC files, but not the new ones I created with the newest Foobar. And yes, I have the newest FLAC codec offered by Db and its installed to the correct directory.
      Thanks for your help.
        • 46184
        Install R12 (in the beta section) this supports the latest FLAC.
