How do I encode with cyrillic text in CD audio input
  • Paelor
    • May 2006
    Sorry if this is obvious or already answered, but I've spent hours searching the solution.
    I'm having trouble getting cyrillic text into CD audio input, and therefore cannot encode my flac or other file formats with it. My computer seems to support it, because it copies to the clipboard correctly and even into CD audio input when you rename a song or artist, however as soon as you finish renaming the field, it changes to a string of ??????? and doesn't get saved correctly.
    I should mention I've just installed the latest version of dbPowerAmp.
    1, Does CD audio input support Cyrillic/Unicode?
    2, How do I make use of it with Flac or wma?
    Re: How do I encode with cyrillic text in CD audio input
    dMC R12 will be fully unicode compatible, look for the beta forum for updates (currently CD Ripper is being written).
