Help where is the Help
  • BLUIE
    • May 2005
    Just registered DBWriter and at the end of the install it opened some sort of getting started help document. Inadvertently :o closed that and now can not find it again. So Help where is the Help file? Or point out any other manuals that would help a beginner. Without that I am going to have a whole :D google of questions.
    Re: Help where is the Help
    You can access the Help files through the ? icon on the dB CD Writer main screen or through Start>All Programs>dBpowerAMP Music Converter>Help>dB CD Writer Help.
    Bill
    • BLUIE
      • May 2005
      All right that got the little monster. Would you believe I so seldom use the Start menu I never thought of looking there. Thanks :komisch9:
