Increasing Volume
  • zeichen
    • Jan 2006
    Increasing Volume
    [COLOR=Navy]DOES ANYONE KNOW HOW I CAN INCREASE VOLUME ON MP3 FILES PLEASE? I HAVE AUDIOBOOKS THAT I CAN HARDLY HEAR ON MY IPOD WHICH RESTRICTS VOLUME LEVEL - IF THERE IS OUTSIDE NOISE THEN IT IS IMPOSSIBLE TO HEAR - SO IS THERE SOFTWARE THAT INCREASES THE NOISE LEVEL SO I CAN RERECORD TRACKS AT A HIGHER LEVEL PLEASE?[/COLOR]
  • Deano
    • Jan 2006
    • 130
    Re: Increasing Volume
    Have you tried normalising your files when ripping/converting using dbPowerAMPs DSP effects?
    You could also try mp3gain, if you are using mp3's anyway.
