Recording Streaming Audio
  • jim1812
    • Aug 2002
    Dont really know if this is the proper place to ask this question or whether it should go to Spoon. But at the flip of the coin, you won! :confused:
    I want to record some of the plays presented on BBC Radio 4. I understand that I need to use my sound card to do it but from there on I am lost. So can someone explain to this old Yank just what the h**** I have to do and how?
    Thanks, Jim1812
    If you install Auxiliary Input, on the Options page select input source, some sound cards let you record what is being played in another program.
      StreamboxVCR
      Search for streamboxVCR - brilliant for capturing both audio and video streams The possibilies are endless.
      You will also need
      the stealthmulder crack for StreamboxVCR
      URL fetcher to find some hidden stream source
      realplayer (basic 8 recommended)
      You can dl the files to listen/ watch l8r!
      Enjoy!
      • MasterOfPuppets
        • Nov 2002
        • 139
        If your sound card doesn't support recording from mixed output, you can just connect the output of your sound card to the line in with an audio cable (costs like a buck @ most), and then use Auxiliary Input to record from the line in while playing the shows.
        Toute votre base sont appartiennent à nous!!!
