continuous (live) tracks
  • steerpike
    • Jul 2005
    • 9
    What's the best way to handle a live concert CD ... I'd like to convert it in such a way that, on playback, each track 'flows' into the next track - no 'gap' between the tracks. Is this a feature of how the track is ripped, or are there other factors? My goal is to playback on an MP3 player.
    Thanks!
    Re: continuous (live) tracks
    The mp3 format itself is not gapless.
    Your cd is made up of X separate tracks, but the gap between the tracks is for all intents and purposes nil. That's why when it's played it sounds continuous.
    When you rip normally it you will produce X audio files. But in dMC Audio CD Input there is an option to Rip as one. That will rip the cd and produce one single audio file. This is probably what you'd like to have.
    I'd recommend though also riping the tracks individually in case you ever need them separately.
      In addition to what Christina has stated, you should be aware that mp3 inserts a very slight gap at the end of each track you convert to mp3. The one exception to this is the Blade codec from Codec Central (link at the top of the page).
      My own recommendation is that you first try the Lame codec and then give Blade a try if you need to.
      Please be aware also that not all mp3 players support ggapless playback (in which case your only option would be the rip as one option described by Christina).
      With a cd ripped using the rip as one you will only be able to listen to the cd as one continuous track. dMC cannot bookmark the separate tracks (which is why Christina notes that you would probably want to convert each track individually as well.
      Bill
      • GSV3MiaC
        • Jun 2005
        • 68
        There are very few, if any (?) MP3 players which support gapless playback yet (a feature of the chip(s) they are all built around). For my 'continuous' CDs ('Days of Future Passed' spring to mind, or Carole King's 'Fantasy') I just ript he whole thing as one track.
          I normally rip to wav - it takes the guessing out of it and it's lossless. Then I dont' have to bother with the cd again. I might change this method eventually to rip to wma lossless perhaps if I find space becomes a problem.
          So for starters I'd rip the whole thing to one single lossless format file, also rip each track to individual lossless format files.
          Then I convert to whatever formats I need from the lossless format I used. That involves some degree of guessing at times, in the quest for the best compressed formats or the best quality with the given constraints I may be working with.
          • dc8driver
            • Nov 2005
            Christina,
            New to the forum. Where exactly is this feature to rip as one file? I have been lokng for this to rip my mixed cds. Thanks..
            DC
              It should be in the top right hand corner in dMC Audio CD Input, right under the PowerPakc rocket.
                The "Rip as One" button is right-next to the "Compilation" button and, as ChristinaS said, under the PowerPack rocket.
                Note that it is a Power-Pack only feature.
                • gameplaya15143
                  • Sep 2005
                  • 276
                  creating a cd where the tracks flow into the next is dependend on 2 things
                  1) how you rip/record/encode it
                  2) how you burn the audio cd
                  stick with wav/pcm while you work with the content, its easier, everything can open it, better for editing, etc.
                  if you burn the cd in track-at-once, there will always be a 2 sec gap between tracks. so burn in disk-at-once, then there doesnt have to be gaps between tracks
