.asx to play forever
  • strangheart
    • Aug 2005
    hi
    can any one help me
    i want the .asx file to play forever
    it plays the songs than stops
    i want it to play for ever
    is there any coding for this
    thank you :blush:
    Re: .asx to play forever
    What program are you using? Normally, there is an option in the version of WMP to "play song x times" or just to loop the file continuously.
    • strangheart
      • Aug 2005
      :o
      i am using media player for the web site
      i did not understand what u meant by which program
      i have made it for the website
      using .asx
        Ahh, you have the file embedded in a webpage. Well, I'm sorry to say I can't help you there, as I have no experience with webpages.
        Moved to General section of the forum.
        • neilthecellist
          • Dec 2004
          • 1288
          What do you mean by "play forever"? Do you mean you're experiencing network hitches? Or do you mean that the song won't repeat?
          If it's because of network hitches, i can't help you. If it's because it's an ASX file that you want to listen via your harddrive over and over again, use dMC Auxiliary Input.
            Neil: He wants to embed a .asx file in a webpage and have it repeat indefinately.
            Can anyone answer this question?
            • strangheart
              • Aug 2005
              The file is already embed and working
              but i want it to play repeatedly
              yes u r rite Neil:
              i want to run it infinitly...
              • neilthecellist
                • Dec 2004
                • 1288
                ChristinaS would know...Where is she? She's usually online around this time...
                • strangheart
                  • Aug 2005
                  [SIZE=6]what are you saying [/SIZE] :yawn: :p
                  • donny
                    • Oct 2002
                    • 761
                    neil, you can't always expect everyone to be online ...
                    I guess no one else has experience with this kinda stuff... I would suggest searching help from google, there should be a bunch of pages online about developing web pages, so there should be some that cover this problem.
                    • strangheart
                      • Aug 2005
                      hi
                      i found it its easy
                      <repeat count=2> // if u put only "repeat" it will play for infinity/
                      <enter>
                      </enter>
                      </repeat>
                      • donny
                        • Oct 2002
                        • 761
                        glad it worked
