iTunes importation
  • Grann0n
    • May 2005
    iTunes importation
    Hi all,
    I'm converting some MP3 to M4A format using the dbpoweramp converter and everything is OK but each time iTunes finished to convert a file, I got a (edited curse words) windows sound and I can't find which one it is and obviously to deactivate it
    If sb could tell me where I can find it because there is nothing in iTunes option and it make me crazy :yawn:
    Thank you
    Re: iTunes importation f**king sound
    First, please don't curse. Second, you could use a different m4a encoder than the iTunes one if you want. See here: http://forum.dbpoweramp.com/showthread.php?t=7417
    • Grann0n
      • May 2005
      I'm not cursing, I'm only grumbling
      Anyway, the whole system is OK and I'm fine to use iTunes. I'm just looking to disable this sound .
      That's all and if you feel stressed by me or my question, I can go away.
      As you want
        Can't help with the iTunes part, as I don't have/want iTunes installed. Somebody else should be able to help, though.
