Customize Send To Menu
    Is it possible to customize the Send To menu to send mp3/wma files to a portable device? I don't like the software that came with my MP3 player so I'm looking for an easier way to transfer. Ideally I'd like to connect the player to the USB, right click and "send to" without open the sofware.
    JV
  • totalXSive
    • 222
    Get Sveta Portable Audio. Assuming your player is supported (most are), you can right click a file, select Convert To, select your player, select the format then click Convert. It will then convert the file to the correct format and upload it for you.
    Click on the Downloads link above.
    [size=2][b]Neil T :)[/b]
    [url=http://www.neilturner.me.uk/]My weblog[/url] [url=http://www.audiopod.co.uk/]AudioPod - MP3 news[/url] :cool: [/size]
