Monkeys Audio WOW!
  • Smoggy
    • Feb 2005
    • 120
    Monkeys Audio WOW!
    Monkeys is sooo fast!!!
    It took 1 min 46 sec to rip an entire CD....Hmmmm.....
    It seems like it's way faster to rip in APE format than Mp3....The average Mp3 rip takes about 10 min for me @ 320kbps
    Bizzarre!
    I thought Ape would be slow since it produces a much bigger file.
    Can NE 1 explain this???
    Smogg
  • Smoggy
    • Feb 2005
    • 120
    Re: Monkeys Audio WOW!
    WOW just ripped a 1:12:32 length CD in 2 min 25 sec....
    I'm falling in love with Monkey..... :shocked: Ok wait....that sound sick and wrong......
    Smogg
      10 minutes to rip a CD to mp3? What are your system specs?
      Edit: then again, it IS 320kbps. How long does it take to rip at, for example, 192kbps?
      • Smoggy
        • Feb 2005
        • 120
        AMD 2.1...I think
        768 RAM PC3100 Kingston
        Umm what else....
        40X Sony CD Drive
        ummmm
        7200 RPM HD Hitachi
        Albatron KX600 Pro MB
        cant remember FSB speed or BUS speeds
        Do you think my Puter my be having some issues I need to work out?
        How long should it take to rip a full length CD to Mp3 at 320kbps?
        I can't remeber how long it took to do a 192kbps ...I have been pretty much using 320 since I figured out how to change it.
        FSB 200/266/333/400 MHZ
        Not sure what i'm set for tho
        Smogg
          2.1 OC or not? And what's the model number?
          Your FSB is probably 333 if its not overclocked.
          As for how long it SHOULD take to rip to 320kbps mp3.. don't know, haven't used mp3 except for friends (at 192) since I found Ogg and Monkey's.
          • Smoggy
            • Feb 2005
            • 120
            Not OC'd...I can't remember mod# I bought it so long ago
            Smogg
              You either have a 2700+ or 3000+ with 333FSB or a 3200+ with a 400FSB. With your ram, I don't think your running the 3200+ though.
              • Smoggy
                • Feb 2005
                • 120
                Ahhh Found my recipt ok I was wrong It's Mushkin PC2700 and.......Athlon XP 2400 Thornton/ AXDC 2400DKV3C .......CPU#15588....FSB 266..I was way off :D
                Smogg
                  2400+ means your running at 2.0Ghz clock.
                  Anyway, try ripping a CD to 192kbps mp3 and see how long that takes.
                  • Smoggy
                    • Feb 2005
                    • 120
                    OK
                    Mp3 @ 192kbps it took 4:21
                    Monkey @ Fast setting it took 2:24
                    on a 1hour 2 min CD
                    Smogg
                      Hmm. How long to rip to WAV?
                      • Smoggy
                        • Feb 2005
                        • 120
                        You're killing me!
                        Hang on lemme try that.
                        Smogg
                        • Smoggy
                          • Feb 2005
                          • 120
                          OK 2:21 for WAV
                          Smogg
                            Hmm. Guess mp3 at high bitrates consumes more CPU as it tries to digitize the signal. Kinda obvious, but still in need of mentioning. If I may ask, why 320kbps and not just a different format?
                            • Smoggy
                              • Feb 2005
                              • 120
                              It's all been kinda of a learning process for me..... I am very anal about the quality of my music. I started with the standard 128kbps and started noticing minute flaws (I have sensitive ears) and decided to go with the best possible quality mp3 bitrate. After I had ripped my 350+ CD collection, I then learned of lossless. So now I must re rip my entire collection to APE and also keep my Mp3s for my portable player even tho I'm not happy with the quality I hear.
                              I'm also considering selling my Nomad 40GB mp3 player....especially since I cannot find an interface to play it through my car stereo. I was thinking "this is awesome I will never have to change a CD ever again" DOH!!!!!
                              So to sum it up I'm anal and want the best music copys possible!!! LOL :komisch7:
                              Smogg
