Registered User and want latest bug fixes for dMC Audio CD Input
  • datsun120y
    • Mar 2005
    Hi there
    As the title says I am a registered user of your products, which are fantastic , and really appreciate the obvious huge amount of time that you have spent producing the ALT presets for CD Ripping :smile2: they do a fantastic job and make ripping real easy.
    I have however run into the problems with filename and path bugs :( with the dMC Audio CD Input. Is it possible to install the latest version with bug fixes as a registered version ? Or do I need to wait for this version to become the latest stable version before I can install ? (if so do you have any time scale on this ?)
    datsun120y
    • 46229
    Re: Registered User and want latest bug fixes for dMC Audio CD Input
    The latest CD Writer is R2 - you can download this through the online registration updating link:
    If you are referring to bug fixes in dMC R11.1 then yes this can be installed over the top of a CD writer to give the latest version.
    • datsun120y
      • Mar 2005
      Spoon, I am confused now, I am talking about the updates to DMC. do I just download http://www.dbpoweramp.com/beta/dMC-r11.1beta2.exe and install?This seems to be going to install the whole lot again ??
      Datsun120y
