Trouble using the Spoon Installer maker thing
  • PetMetroid
    • Dec 2004
    I understand that this program isn't your's, but you use it for installations. The support page for the Spoon installer isn't very good, so I'll see if anyone can help me here...
    With the Spoon Installer program, I basically want to create an installation that extracts a zip file (containing folders) into the program files, activates an icon for the finished product onto the desktop, and open a readme. But first things first, how do get a zip fle to extract?
  • Razgo
    • 2532
    Re: Trouble using the Spoon Installer maker thing
    i'm not familiar enough with the installer to commment but i do know it is Spoon's product and he is the owner.
      Why extract a ZIP file? the latest Spoon installer uses LZMA compression which is 2x better than zip.
