Became Unregistered
    Became Unregistered
    I've gone from bad to worse. I just installed WIndows Media Player 10, and dBpowerAMP won't rip anymore because it says it doesn't have the proper (WMA) codec. I went to CODEC Central and reinstalled it to no avail. I then uninstalled dBpowerAMP and resinstalled it in the hope it would recognize the environment. That didn't work either, and now it says I'm an unregistered user, even though I installed the registered version.
    I tried going to the "download new registered version" Web site, and all it gives me is a blank page.
    What can I do to become a registered user again, and have dBpowerAMP work with Windows Media Player 10?
    Re: Became Unregistered
    For the second part, download and install the system file and WMA 9.1 from the beta test section of the forum here: http://forum.dbpoweramp.com/showthread.php?t=6128
    The 9.1 codec is designed for WMP 10.
    We'll worry about the registration piece tomorrow.
    Bill Mikkelsen
    • Razgo
      • 2532
      for registration problems send Spoon an email from this page http://www.dbpoweramp.com/email.htm
      • DRDRD
        • Nov 2004
        Things are improving. The new CODEC worked after some tweaking of the compression parameters. Thanks for the help. Unfortunately, I don't have time tonight to get details on the registration problem, so I'll take care of that tomorrow night. Thanks again.
        Also, as a suggestion, I looked around (I thought) pretty thoroughly for the issue of WMP 10 CODEC problems and didn's see anything. You might want to make it more prominent, especially on CODEC Central.
