44.1khz...
    44.1khz...
    Hi, I read in Spoon's audio guide that there's no point in converting audio from a CD to a file that is 44.8khz. If I convert a lossless file (which was converted from an audio cd) to an lossy format like AAC in 44.8khz, will there be any 'side effects'?
    Re: 44.1khz...
    The two biggest drawbacks of encoding to 48 khz rather than 44.1 khz will be: 1. You will use up more disk space; 2. The files might not be as playable in all other players as if they were recorded at the standard 44.1 khz.
      Re: 44.1khz...
