iPOD transfers
  • Codec Newbie
    iPOD transfers
    Hey gang,
    Well, i've got the encoder working fine now, ripping at approx 256kbps which is great, only trouble is when i try to drag and drop these files into the itunes window, nothing happens! itunes will play the tracks when selected from my HD, but won't transfer them to the ipod's library. I want to try to avoid downloading yet another program - any suggestions?
    thanks
    Specs
    Re: iPOD transfers
    iTunes only likes .m4a files, so you can either:
    Try dBpowerAMPs Sveta to transfer to the iPod, or edit \dbpoweramp\compression\FAAC\options.txt so the extension is .m4a
    • Codec Newbie
      Re: iPOD transfers
      Thanks Spoon, I'll try that
