may i know how to convert AVI files to audio format such as MP3.....i dont know which codec to download...thanks in advance,...
	This topic is closed.
	Tags: None
 Re: how to convert AVI files to audio format
 Is it strictly an audio avi or does it have a video component too?Originally posted by ar_majnu2002may i know how to convert AVI files to audio format such as MP3.....i dont know which codec to download...thanks in advance,...
 dMC Auxiliary Input can capture and record the audio portion to any type of file for which you have codecs as per: http://forum.dbpoweramp.com/showthread.php?t=5362
 There appear to be no codecs for conversion involving dMC.
 Other products can do it:
 One is to use Windows Media Encoder and encode to wma and thereafeter
 convert the wma file to wav or mp3 or any other format. This works in real time. Pretty confusig so best to avoid it actually.
 Another is using the Audio Converter program (download for free from http://audio-video.ws/download.html ). I haven't used this one yet, so I cannot comment on how it works (or doesn't).
 I strongly recommend "Easy Audio Editor" which can convert AVI files to audio format,it's easy to use, you can have a try from http://www.mediasoftzone.com/Audio-M...io-Editor.html
 hope it helps!Comment
 Thread locked. The original is over a year old and I'm sure there are other threads that cover this.
 Auxiliary Input will work. There is also VirtuaDub, I think it is called, that can rip the audio out of a video.Comment
