It looks like everything is happening correctly while recording from an album on my turntable but when I play back the file it is only a few seconds long. If I record the album as just one track it works but when I define tracks with breaks, no luck. It switches tracks ok during recording. The recording control makes it look like the whole album was recorded without problem
Problem ripping from LP in DB Aux Input
Re: Problem ripping from LP in DB Aux Input
Take a look at this thread. http://forum.dbpoweramp.com/showthread.php?t=5469 .Originally posted by johnhgsIt looks like everything is happening correctly while recording from an album on my turntable but when I play back the file it is only a few seconds long. If I record the album as just one track it works but when I define tracks with breaks, no luck. It switches tracks ok during recording. The recording control makes it look like the whole album was recorded without problem[B][url=http://www.webado.net/][COLOR=Blue][FONT=Comic Sans MS]Christina[/FONT][/COLOR][/url][/B]
[COLOR=RoyalBlue]SVP, ne pas me demander du support par PM. Veuillez poster vos questions dans le forum pour le bénéfice de tous.[/COLOR] -
It looks like everything is happening correctly while recording from an album on my turntable but when I play back the file it is only a few seconds long. If I record the album as just one track it works but when I define tracks with breaks, no luck. It switches tracks ok during recording. The recording control makes it look like the whole album was recorded without problemComment
It could be that dMC Auxiliary Input is incorrectly identifying the gaps between the tracks due to what setting you are using.
Do the tracks on the LP you are recording have any silent or quiet sections? Try adjusting the sound level etc. and see if that improves things. I can't remember, but I think that the Auxiliary Input program stops recording once the number of tracks it is expecting to record have been created.
Alternatively record it as a single file and after the recording is complete split the large file into separate individual tracks.
WayneComment
