Playlist Volume Normalizing
  • enthios
    Hi. I've got a playlist of songs from 30 different CD's of my favorite band. The volume levels are all over the place. Is there a way to normalize the playlist (or any list, for that matter) of a large number of songs? Perhaps by doing a batch conversion?
    Thanks so much.
  • drspy00
    • 104
    Re: Playlist Volume Normalizing
    You can add all the files you want normalised into dbpoweramp converter and normalise and convert all at once to the file format you want, even the same format. I hope I could help.
    • enthios
      Sounds good - do all of the songs have to be in the same directory? I don't see how I can select files from different folder?
      - M
      • ferris209
        • Oct 2003
        • 181
        If they are mp3 format, use this handy little program!
        MP3Gain - A free automatic mp3 volume normalizer
        "It's better to have it and not need it than to need it and not have it!" - John Wayne
        [URL=http://www.powersnipe.com?upartner=21095]Powersnipe is the best for Ebay![/URL]
        • drspy00
          • 104
          I think that you can just open an mp3 playlist in dmc and it converts all songs in the playlist. I forgot about that function, i think its there anyway.
