MPC Quirks
  • JahSun
    • Nov 2003
    • 69
    MPC Quirks
    I've noticed a few funny quirks while using the MPC codec recently. I've always messed with it a bit, but tended to prefer my more universally compatible codecs for various reasons. However, since Nero released MPC support, I have ressurected MPC due to its great bass response.
    Anyhow, my recent MPC conversions sometimes produce funny quirks.
    1) once in a while, the tag will contain a strange PETAGEX value for one of the fields, and it is often very difficult to change this to its correct value.
    2) sometimes when deleting an MPC file made with DMC, it will tell me that the file is write protected or some other error warning usually with a (5) at the end. often it gives me 3 or 4 pop up errors, but after clicking ok on them all, the file is in fact deleted.
    There are a couple other strange things that aren't a big deal, and could go completely unnoticed until you mess around with the files for a while. I'll try and document the exact circumstances and the exact error response, but in the mean time perhaps someone could enlighten me about this. I never have these issues with other codecs, and I can't remember if the old MPC codec also had these quirks... but I want to say that it didn't. (At least I don't remember encountering them back then)
    Any Ideas?
    Re: MPC Quirks
    I know about both of these, the first one should be solved soon with a codec update (it is detecting the APE2 tag wrongly as an ID3v1 tag).
    The 2nd problem is the yellow get popup info is accessing the file whilst you are trying to delete it, all I know is if you select 2 files none of them will be accessed.
    • JahSun
      • Nov 2003
      • 69
      Re: MPC Quirks
      Cool... Thanx Spoon. As always you de man. (I rarely need to delete more than one file at a time, so the 2nd workaround may not help me... but it is good to know that it is not a problem with my system or setup)
