MF Digital Baxter help!
  • crow
    • Nov 2022
    I have managed to find an MF Digital Baxter 9100 on eBay, however it has arrived without a power supply. I've messaged the sender to ask if they still have it, but if it turns out they don't I wondered if anyone else here has any experience with this ripper?
    The power connector seems to be propietary or at least one I haven't seen before. I might have to try and homebrew a replacement cable and it would help me a lot of anyone can share any info you can with regards to the input voltages and frequency and what pins to power. I'm in the UK, if that helps.
    Really hope someone can help, I really wanted to get some automatic ripping on the go and I don't want to be left with a paperweight. :(
    Thanks in advance!
  • marcusm
    • Jul 2020
    Re: MF Digital Baxter help!
    Hi It is a 5 V 2000 ma (2A?) output. The end is a circular barrel type end with a small crimp in one side with four pins.
