Auxilliary Input
  • dig412
    • Jan 2004
    • 48
    Auxilliary Input
    I have auxilliary input 3 and the latest power pack. The power pack options do not appear in aux input. They are in all the other programs i have. Do i need the latest aux input version?
    [left][url="http://www.nationstates.net/"][/url] [/left]
  • Wayne
    • Aug 2002
    • 1254
    Re: Auxilliary Input
    I would recommend that you download the latest version, which is 4, of Auxiliary Input and try that.
    I've had the power pack installed for so long that I occasionally forget that some dMC features are only available when it is installed ;-)
    Wayne
    • dig412
      • Jan 2004
      • 48
      Wher can you get release 4? On the dmc download page it says release 3, and the isnt any referance in the beta forums.
        Release 4 is in the Beta section of this forum.
        Try running this if the power pack is not appearing:
