moving questions
  • vintageveloce
    • Nov 2010
    • 24
    moving questions
    I'm moving to a new PC and have settings in the various dBpoweramp apps that I want to move as well. I'd rather not have to retype all my custom naming setups and path names, etc.
    I see the settings are kept here:
    Code:
    in the registry:
    HKEY_CURRENT_USER\Software\Illustrate
    and this path:
    %appdata%\dbpoweramp
    Am I making any mistakes just copying these over to the new PC? Are there and optical drive details or other PC specific features that I should "reset" or "relearn"?
    • 46171
    Re: moving questions
    No those are the two locations
    • vintageveloce
      • Nov 2010
      • 24
      Are there any optical drive details or other PC specific features that I should "reset" or "relearn"?
      • vintageveloce
        • Nov 2010
        • 24
        OK just for reference:
        The Registry did contain the CDRipper profiles I wanted to move. Excellent.
        I also see it has some "drive settings" After I did my first rip on the new computer the new drive was added to the registry drive settings.
        For the other settings in Windows 10, the path I found was
        C:\Users\<username>\appdata\Roaming\dBpoweramp
        Note, I placed illustrate the folder on the new PC in the proper location and updated the new computers registry BEFORE installing dBpoweramp, and that worked fine.
        I also bought the latest version of the SW while I was at it. Still great stuff. Thanks Spoon!
