Software for playing flac filds with wsindows 64-bit
  • Tom Swaman
    • Oct 2011
    • 258
    I am in the process of upgrading my hardware. I store about 5 TB of high quality FLAC music files and use Windows 64-Bit. I presently use Asset and LINN Kazoo with Sim Audio and LINN hardware. I play stereo music through four discrete hardware systems.
    Frankly, I like everything IU am using except LINN Kazoo.
    MY question is can someone one or more of you recommend a top quality, reliable and easy to use system of player software or player and server compatible software that will yield good results in my system?
    Thanks much for the assistance,
    Tom Swaman
  • Tom Swaman
    • Oct 2011
    • 258
    Re: Software for playing flac filds with wsindows 64-bit
    What players are available?
      Software players on windows?
        foobar2000 for windows.
        • Tom Swaman
          • Oct 2011
          • 258
          garym,
          Many thanks.
          Does Foobar work well with Asset? Will Foobar enable assembling and saving large playlists?
          I am frying to replace LINN Kazoo. Will Foobar do the job?
          With appreciation,
          Tom
            garym,
            Many thanks.
            With appreciation,
            Tom
            not sure. Do not use ASSET. Sorry.
            • Tom Swaman
              • Oct 2011
              • 258
              Spoon,
              I am trying to play FLAC music files stored on a Windows 64-Bit computer. I need to be able to play through 3 LINN DS systems. I currently use Asset and LINN Kazoo. I wish to replace Kazoo.
              Thank you for your help,
              Tom Swaman
              • Tom Swaman
                • Oct 2011
                • 258
                DOES ANYONE USE FOOBAR???
                Many thanks,
                Tom Swaman
                • schmidj
                  • Nov 2013
                  • 599
                  I use Foobar, but not usually with Asset, although I have on occasion.
                  Foobar has a bit of a setup learning/configuration curve, but other than that issue, works well.
                  I've run into an issue using the mobile (Android) version in my car. Instead of pausing the music when I shut off the engine and the Bluetooth goes away, it switches to the phone speaker, not what I want! So I use a different player in my phone. But the PC version works fine once set up.
                  • Tom Swaman
                    • Oct 2011
                    • 258
                    schmidj,
                    I thank you. I am sorry I have not written sooner.
                    What do you use as a music server with foobar as a player? How large can you make and store a playlist?
                    Thanks again,
                    Tom Swaman
                      foobar2000 is a server as well as a player.
                      • Tom Swaman
                        • Oct 2011
                        • 258
                        Thanks Gary.
                        Regards,
                        Tom Swaman
                        • Tom Swaman
                          • Oct 2011
                          • 258
                          Which players(software) do folks use with Asset on Windows/Android?
