Context menu entries (Edit-ID tags, Convert to, ...) have gone missing
  • Bluefin21
    • Aug 2015
    • 11
    I have recently upgraded to R17 (Windows10), but I can't be 100% sure there wasn't a problem before that.
    I use the "Edit-ID Tags" right-click menu option quite a lot. But it has now disappeared - apparently for all media types (certainly mp3, mp4, flac, and m4p). I have tried pretty much every combination/sequence of turning the option on/off, with rebooting inbetween, re-installing R17, uninstalling/rebooting/reinstalling R17, uninstalling R17/rebooting/reinstalling R*16*, etc. that I can think of. And now I'm back to R17.
    Subsequent to all that, I tried turning on the "Convert to" option (previously off), which caused a "need admin rights, you sure" type popup (sorry, can't remember the proper name :-)). Immediately after that, the Convert-To and Edit-ID Tags options appeared for mp3, m4a and flac - but still not for mp4 or m4p. (At this point also tried turning off both Convert-to and Edit-ID, then turning them both on again - and got back to this same state).
    I have seen on the forums similar issues in the past, but generally they seemed to get resolved by combinations of off/reboot/on/reinstall which obviously doesn't seem to be working in my case. Do you have any other suggestions?
    P.S. This may be a stupid question, but as a workaround I'd be happy if I could start the Tag Editor as a standalone application - but I can't see a way to do that. Is there one?
  • Bluefin21
    • Aug 2015
    • 11
    Re: Context menu entries (Edit-ID tags, Convert to, ...) have gone missing
    In the absence of a reply (which I suppose is encouraging in a way, 'cos it means I probably haven't done anything particularly stupid :-)), I've got hold of the Nirsoft ShellExView tool (https://www.nirsoft.net/utils/shexview.html) to see what's registered - as I believe it's these Shell Extensions that add things to the context menu(?). It shows 5 entries for dbPoweramp. I can't see anything obviously wrong, but if anyone is able to compare the output on a working system I would appreciate it.
    Extension Name : dBpoweramp Property Handler
    Disabled : No
    Type : Property Handler
    Description : Explorer Property Handler
    Version : 17.0.3.0
    Product Name : dBpoweramp
    Company : Illustrate
    My Computer : No
    Desktop : No
    Control Panel : No
    My Network Places : No
    Entire Network : No
    Remote Computer : No
    Filename : C:\Program Files\dBpoweramp\dBPropertyHandler.dll
    CLSID : {c0212cf9-9262-6e84-a7d9-492f82466cff}
    File Created Time : 16/04/2020 21:20:13
    CLSID Modified Time: 16/04/2020 21:47:15
    Microsoft : No
    File Extensions :
    File Attributes : A
    File Size : 241,840
    .NET Extension : No
    Digital Signature :
    Missing File : No
    Extension Name : dBpoweramp Thumbnail Handler
    Disabled : No
    Type : Thumbnail Handler
    Description : dBThumbHandler
    Version : 17.0.3.0
    My Computer : No
    Desktop : No
    Control Panel : No
    Entire Network : No
    Filename : C:\Program Files\dBpoweramp\dBThumbnailProvider.dll
    CLSID : {72f06720-4c02-6020-05d0-40d748699f3d}
    CLSID Modified Time: 16/04/2020 21:47:16
    Microsoft : No
    File Extensions : .aac, .aif, .aifc, .aiff, .ape, .asf, .asx, .bwf, .caf, .cda, .dff, .dsf, .flac, .m2a, .m4a, .m4b, .mp+, .mp1, .mp2, .mp3, .mp4, .mpa, .mpc, .mpeg, .mpg, .mpga, .mpp, .mpx, .oga, .ogg, .opus, .spx, .wav, .wma, .wmv, .wv, .wvx
    File Attributes : A
    File Size : 200,880
    .NET Extension : No
    Digital Signature :
    Missing File : No
    Extension Name : dBpShell Class
    Disabled : No
    Type : Column Handler
    Description : Provides dBpoweramp Shell Interaction
    Version : 17.0.3.0
    My Computer : No
    Desktop : No
    Control Panel : No
    Entire Network : No
    Filename : C:\Program Files\dBpoweramp\dBShell.dll
    CLSID : {FED7043D-346A-414D-ACD7-550D052499A7}
    File Created Time : 16/04/2020 21:20:10
    CLSID Modified Time: 16/04/2020 21:31:37
    Microsoft : No
    File Extensions : Folder, opensearchfilefolderresult
    File Attributes : A
    File Size : 789,680
    .NET Extension : No
    Digital Signature :
    Missing File : No
    Disabled : No
    Type : InfoTip Handler
    Version : 17.0.3.0
    My Computer : No
    Desktop : No
    Control Panel : No
    Entire Network : No
    Microsoft : No
    File Extensions : .aac, .aif, .aifc, .aiff, .ape, .bwf, .caf, .dff, .dsf, .flac, .m2a, .m4a, .m4b, .mp+, .mp1, .mp2, .mp3, .mpa, .mpc, .mpga, .mpp, .oga, .ogg, .opus, .spx, .wav, .wma, .wv, DMCConvert
    File Attributes : A
    File Size : 789,680
    .NET Extension : No
    Digital Signature :
    Missing File : No
    Extension Name : dMCIShell Class
    Disabled : No
    Type : Context Menu
    Description : dMC Shell Module
    Version : 17.0.3.0
    My Computer : No
    Desktop : No
    Control Panel : No
    Entire Network : No
    Filename : C:\Program Files\dBpoweramp\dMCShell.dll
    CLSID : {2C49B5D0-ACE7-4D17-9DF0-A254A6C5A0C5}
    File Created Time : 16/04/2020 21:20:11
    CLSID Modified Time: 16/04/2020 21:31:38
    Microsoft : No
    File Extensions : .aac, .aif, .aifc, .aiff, .ape, .asf, .asx, .bwf, .caf, .cda, .dff, .dsf, .flac, .m2a, .m4a, .m4b, .mp+, .mp1, .mp2, .mp3, .mp4, .mpa, .mpc, .mpeg, .mpg, .mpga, .mpp, .mpx, .oga, .ogg, .opus, .spx, .wav, .wma, .wmv, .wv, .wvx, DMCConvert, .aac, .aif, .aifc, .aiff, .ape, .asf, .asx, .bwf, .caf, .cda, .dff, .dsf, .flac, .m2a, .m4a, .m4b, .mp+, .mp1, .mp2, .mp3, .mp4, .mpa, .mpc, .mpeg, .mpg, .mpga, .mpp, .mpx, .oga, .ogg, .opus, .spx, .wav, .wma, .wmv, .wv, .wvx
    File Attributes : A
    File Size : 4,323,504
    .NET Extension : No
    Digital Signature :
    Missing File : No
      mp4 is excluded by default, it is in the sub menu of exclusions, because .mp4 is normally a video file.
      .m4a is audio and .m4p is protected audio which dBpoweramp will not touch.
      • Bluefin21
        • Aug 2015
        • 11
        Ahhhhhhhhh, thank you so much!
        Went to the dBpoweramp Advanced Settings, unticked .mp4 under "Exclusions" against the "Convert To" option,and all is now right with the world :-)
        Easy when you know how!
        Thanks again.
