dbpoweramp or TuneFusion
  • kkhan
    • Nov 2017
    • 12
    I am a long-term user of Asset which I love (the best software is setup and forget it is even there!) but recently I purchased a car with a 7.1 surround system and have ripped some blu-ray music soundtracks as FLAC 7.1 files. However, they are unplayable in practise because the dynamic range is so wide - becomes very uncomfortable at speed.
    So considering to purchase dbpoweramp or TuneFusion - they both seem to do the same thing for my purposes. Which is more appropriate?
    Would I be able to normalise 7.1 24/96 FLAC files?
    Thanks for any advice.
    Re: dbpoweramp or TuneFusion
    The standard normalization is EBUR128, which I think is stereo only. You will be able to Peak to Peak normalize though with either software, try both trial to determine which is more suited.
