CODECs not for OSX versions?
  • Sounds2Good
    • Apr 2019
    • 11
    I am confused about the usability of the CODECs with the OSX versions of DBPoweramp and Perfect Tunes. In particular I need to use the utility CODEC "Tag from Filename" because I have thousands of ripped tracks where the identification info is in the file name, and no ID tags were written in the FLAC files.
    Is it possible to use this utility CODEC and the other Codec offerings with the OSX (Mac) software?
    Thanks very much.
    Re: CODECs not for OSX versions?
    They are already built into the OSX version:
    see the section enabling utility codecs.
    • Sounds2Good
      • Apr 2019
      • 11
      Thanks very much! I will read the documentation more carefully. I was confused by the text about Windows on the CODEC Central page.
