PC for audio storage/digital o/p
  • Taff
    Have you got any ideas or recommendations:
    a) Fitting a hell of alot of storage, possible 4 to 6, ide 7500rpm 120gig hdd's in a pc?
    b) Control it over a secure wireless network from laptop?
    c) Are there different qualities of cd drives for ripping?
    d) Are there different qualities of digital o/p signal from pc?
    Look forward to reading any thoughts.
  • OldCoder
    • Sep 2003
    • 90
    Re: PC for audio storage/digital o/p
    You only need this for lossless formats, like wav or Monkeys Audio, or if you are a hardware nut. MP3 is a LOT smaller, and a single 120 might do, but with less sound quality.
    Lossless takes about 1/2 gig per cd, so count your album goals up and do the math. Maybe up your drive size to 200 to 250 gig - if you are going to need a lot of space, you might as well minimize the drive count a little bit. Easier on the power supply and heat issues.
    Is this going to be a NAS audio device??? I suspect that wireless might be a little low for ripping and storing, probably ok just for playback.
    Yes, I have tried NEC, Philips, Samsung, and all are blown away by Plextor. Clearly better sound and fewer errors.
    You might want to look at high grade analog output - that allows a hookup to a good stereo with bigger better speakers than what you can get on a PC.
    Good luck on your adventure!
    • RossRoy
      • May 2003
      • 403
      a) you are much better off using 1 or 2 very large drive than 4 to 6 smaller. But, in case you absolutely need 4 to 6 drives, there are PCI cards that can add more IDE ports to your computer.
      b) I personally think wireless does the job wonderfully, especially with the new standards. We're still far from the 1Gb attained with wired, but heck a 1Gb HUB/Switch is still very expensive last time I checked.
      c) Definitely Plextor. I heard Lite-On is good too though.
      d) Someone should correct me on this but isn't a digital signal the same no matter what? So if you have a nice digital receiver and hook up your PC/Laptop to it, the quality will be the same, no matter if you have a low end or high end soundcard. I may be mistaken on that one though. I know for a fact that on analog it applies, get a very good soundcard, but for digital? The soundcard has very little to do with the signal if anything at all. The soundcard ends up acting like a repeater, just repeating the digital signal over the digital wire.
      • Taff
        I am using lossless hence the silly amount of space I would love to have.
        I also thought it would be so much easier to use fewer hdds in a pc but I heard that the larger sizes were not quite as reliable as the more tested smaller sizes such as the 120gig…?
        Thinking of heat & power and the option of the IDE PCI card, larger hdds seems the best option, any thoughts on the Maxtor Diamond drives?
        Sorry I am miles behind,
        NAS audio device?
        1Gb hub/switch? Ideas were to have the pc as a box with music, software, internet connection, etc with a nice –(Plextor)- cd drive for ripping/playing and use the laptop as a remote control for the music software etc – possibly pc anywhere control.
        Wireless should be secure and simple enough for me to sort, should it not…...I hope?
        I have been using 24bit 96kHz to give good analogue i/p to 5.1 amp which feeds nice size speakers, sounded pretty good I thought. I actually tried the “digital pass through” option a couple of days ago, improvement only slight but noticeable. This is why I was wondering if there were different qualities of digital coax signal, I am sure I read somewhere there were two frequencies or something and soon a third will becoming more common which is of course an improvement on the other two – may be talking cobblers but thought I would see if any one else knew.
        Thanks for your advice.
