Spoon Installer Command Line Problem
  • sdotson
    • Dec 2003
    I'm trying to register a dll via the command line
    In the Pre/Post Actions I select Run and in the command line area I type
    regsvr32 /s sDotsoniPropWizard.dll
    I leave the To Run section blank as I don't need to run anything.
    In the PrePost Actions listbox it lists this as Run "
    On install I get a Error on " (I assume the Run " command above)
    Any clues?
    Also how do you go about unregistering this DLL when uninstalling?
    Sean
    • 46186
    Re: Spoon Installer Command Line Problem
    No need, Spoon installer will register and unregister dlls automatically.
    • sdotson
      • Dec 2003
      Great, nice feature. Last question in regards to dlls and ocxs.
      I need to distribute an OCX into the windows/system32 directory. I do not want to overwrite it if it exists. Furthermore on uninstall I don't want to delete it if it does exist.
      It appears that SpoonInstall overwrites the old version and on uninstall delete it.
        • 46186
        It will do, you would have to download the source code and change it for this one.
          Hi. I did the following (since I didn't know that spooninstall would register the file)
          To Run: command.com
          Command line: /C <System>\regsvr32.exe "<Destination>\midas.dll"
          [V] Wait for program to finish
          [V] Optional: Register db-file midas.dll
          The corresponding Uninstall would be:
          To Run: command.com
          Command line: /C <System>\regsvr32.exe /u "<Destination>\midas.dll"
