JPeg vs. PNG?
  • monsterjazzlick
    • 1764
    JPeg vs. PNG?
    Hi folks,
    I have been using JPeg format, exclusively, for all of my folder-art CD images. I always believed this was the best format for this particular task. However, a friend recently told me that PNG is much better/clearer than the former.
    I am not going to re-do all of my art-works again!, and I am not even sure if you can use PNG within 'dBpa', but is it true that one format is superior to the other, please?
    Many thanks in advance,
    Paul
    Re: JPeg vs. PNG?
    For compatibility jpeg is king. When dBpoweramp saves the jpeg files, they are not hugely compressed, so are high quality files.
    • monsterjazzlick
      • 1764
      Re: JPeg vs. PNG?
      OK, thanks a lot Spoon.
      So are you saying that there can be some issues if using PNGs?
      Cheers,
      Paul
        Re: JPeg vs. PNG?
        Yes, not all programs will be compatible with it.
        • monsterjazzlick
          • 1764
          Re: JPeg vs. PNG?
          OK, great; thanks a lot.
          Paul
