Ripping and Batch conversion
  • NME
    • Mar 2018
    General question.
    If I rip my cd collection using FLAC lossless can I then convert to AIFF or ALAC and get the same quality as in the original FLAC lossless rip?
    That is do I have to use the multi encoder function to get the best rip with multiple codecs or is one archivable rip ie FLAC lossless sufficient then use batch converter to get the other formats ie AIFF or ALAC etc. and still have the same quailty?
    • 1932
    Re: Ripping and Batch conversion
    Once you have ripped your CDs into a lossless codec like flac, you can convert those files into any other lossless codec back and forth without any loss of quality.
